It is currently Thu Oct 29, 2026 6:05 pm
 Post subject: For those who haven't seen the stepped flyhigh bags.
PostPosted: Sat Apr 29, 2017 3:01 pm
These are the 550s but I think they hold way more than that. When full they are like 48"×20"x20x minus the step down.Image
 Post subject: Re: For those who haven't seen the stepped flyhigh bags.
PostPosted: Sun Apr 30, 2017 8:07 am
now that's a cool design. Unfortunately, the space the step would consume is where I store all of my std life jackets... :-(
It would mess up the storage feng shui going on in the 23... lol
PostPosted: Sun Apr 30, 2017 8:44 am
I actually pulled these out of a 17 T23 and you still have all your storage under the 2 rear corner cushions when they are full. [emoji6]
PostPosted: Sun Apr 30, 2017 8:43 pm
Do they make a bigger version?
PostPosted: Sun Apr 30, 2017 9:22 pm
Yes they make a 750. These 550s are probably 600s based off measurements I punched into my ballast calculator. I will snap a pic of these full tomorrow. I believe the 750s would take up all rear storage. We had the 550s full in a 2017 A24 and only had about 8" of space left.
PostPosted: Mon Jun 12, 2017 1:39 pm
So I just picked up some fly high 750s (specific to T23/A24 etc) from the dealer and after installing them was surprised to find they were stepped - like your pic. They only have 3 fittings - one bottom front, bottom rear and one on top. The top fitting is the vent fitting for burping the sac. I have a 2015 T23 and the bottom lines fit more or less (no problems with kinks the first weekend).
Question is - looking in the rear trunk, after fore and aft lines are attached, I have a third line coming from the upper/outboard hull side that is attached to the fill valve (currently in the closed position). I assume this is a fill line where the pumps would fill the bag directly from the top instead of filling the bag via overflow from the hard tanks (once they're full) through the bottom fittings. Can I just buy a 1 inch flow rite fitting and swap out the vent plug and attach the top fill line? If I do this, I don't see how I can manually burp the sacs. But if I have another fill line, I assume they'd fill much faster.
Doesn't make sense that the 2017 bags would take a away a top fitting thereby increasing fill time. Do the later model Axis PNP systems do away with the upper fill line?
2015 Axis T23
