It is currently Fri Sep 04, 2026 8:07 pm
 Post subject: Anode broke off
PostPosted: Mon Nov 28, 2016 9:34 am
So I just winterized the boat and removed the anodes back by the transmission for inspection and draining of antifreeze.
One of the anodes was broken off inside and the other anodes was in perfect condition.
Question -- can I leave that broken off anode or do I need to take it to the shop for an expensive teardown and removal of that broken off piece?
Thanks - Jim
Jim Fuller
Lake Keowee, SC
2014 Axis A24
Boat Name: Who's Next
 Post subject: Re: Anode broke off
PostPosted: Tue Nov 29, 2016 4:03 am
If you get a small mirror to look down the hole can you see it anywhere? If so use a pick with some thick grease on the end and try to fish it out, or maybe pull the hoses off each side and flush it out with a water hose
Users browsing this forum: Google [Bot] and 14 guests
