It is currently Sun Oct 25, 2026 1:51 pm
 Post subject: Surfgate fuse location
PostPosted: Sat Nov 19, 2016 6:25 pm
I think I blew a fuse when my starboard surfgate deployed. I manually screwed the ram in. When I try to calibrate or retract them there is no motion. I have read about the fuses being a little weak, but I have never seen anyone say where the fuses are. Anyone know where they are hidden?
 Post subject: Re: Surfgate fuse location
PostPosted: Sat Nov 19, 2016 7:11 pm
Behind the motor you can trace the lines from the gates. Bigger fuses problem solved.
PostPosted: Sat Nov 19, 2016 7:46 pm
Thanks. Found it on port side by xmission. Thanks!
