It is currently Tue May 26, 2026 7:12 am
 Post subject: 2009 A22 Capacity Plate - where is it?
PostPosted: Wed Oct 05, 2016 8:40 pm
Just bought a 2009 that was previously owned by a forum member. I was wondering if anyone can tell me where the capacity plate is as I have not been able to locate it. Also, could you tell me what the official capacity numbers are for the 09?
Thanks,
Marcus
 Post subject: Re: 2009 A22 Capacity Plate - where is it?
PostPosted: Thu Oct 06, 2016 12:10 am
Welcome to the forum. On mine the plate is in the drivers footwell insert. I can get an image tomorrow - I think its 13 passengers.
PostPosted: Thu Oct 06, 2016 9:07 am
Thanks for the reply - an image would be great. I have looked in that area and there is nothing there. However, there is a subwoofer that is mounted in the footwell area and is behind a vented fiberglass area - it wouldn't be back that far would it?
PostPosted: Thu Oct 06, 2016 11:01 am
should be directly below the throttle.
PostPosted: Fri Oct 07, 2016 3:36 pm
Definitely not there... Im not sure if I need to get a replacement or if I can operate without.
Thanks for the replies!
PostPosted: Fri Oct 07, 2016 4:11 pm
Sounds like the footwell may have been replaced and the sub moved there. Here's the image.
PostPosted: Sat Oct 08, 2016 2:55 am
Crazy that the 2009 has a 13 person capacity and my 12' has a 15 person capacity.
PostPosted: Sat Oct 08, 2016 8:06 am
You guys are awesome! Thanks for the pic. I will check and see if it is in the footwell area with the sub.
I believe the '10 has a 15 person capacity. Not sure what changed, but I agree - kinda crazy.
PostPosted: Sat Oct 08, 2016 10:24 am
Mine is a '10 and it's still 13 capacity
