It is currently Sat Oct 24, 2026 3:41 am
A22man
Post subject: Re: What's your top speed? Posted: Mon Oct 03, 2016 12:12 pm |
| Boater |
Joined: Wed Apr 20, 2016 10:18 am Posts: 36 Location: Alberta, Canada
2016 A22 with Monsoon 350, running a 2313 prop, no ballast, 3-4 people in the boat, top speed is around 33 mph as well.
_________________ 2016 A22
pilotflying
Post subject: Re: What's your top speed? Posted: Mon Oct 03, 2016 7:25 pm |
Joined: Thu Oct 30, 2014 7:24 am Posts: 88 Location: Germany
2014 A22 with Monsoon 330 and 2315: 34mph
_________________ 2014 A22
Raimie
Post subject: Re: What's your top speed? Posted: Tue Oct 04, 2016 8:11 am |
Joined: Wed Dec 18, 2013 7:27 am Posts: 239 Location: Harsens Island, MI
2014 T22 with Monsoon 330 and 2315: 34 MPH
_________________ 2018 T22 Previous Boat: 1998 Malibu Sportster, 2014 T22
6wakesurfers
Post subject: Re: What's your top speed? Posted: Tue Oct 04, 2016 8:54 pm |
2015 T22 w/ 409 and 2249 can get to 39-40 depending on wind and chop.
siteki
Post subject: Re: What's your top speed? Posted: Tue Oct 04, 2016 9:06 pm |
Joined: Thu Aug 20, 2015 10:20 am Posts: 15 Location: St. George, UT
2016 T23 w/ Monsoon 350 and 1235 at 2800 feet elevation: 36 MPH
simo47
Post subject: Re: What's your top speed? Posted: Sat Oct 08, 2016 12:43 pm |
Joined: Mon Sep 14, 2015 2:10 pm Posts: 96 Location: Cincinnati
2016 T22 with 409 and 1235. Top speed is 42-43.
SomeYeahoo
Post subject: Re: What's your top speed? Posted: Sun Oct 09, 2016 5:21 pm |
2016 T23, 409, 3600 feet, 1235 prop, 42-43 ish. I drop about 5-6 mph with the 2315. It's lower at 7000+ feet.
eyekode
Post subject: Re: What's your top speed? Posted: Sun Oct 23, 2016 5:04 pm |
| Boater |
I took my boat out one more time to warm up the oil before I changed it:
2014 A22 with LS3 motor and ACME 2419 prop @217 ft above sea level, half tank of gas, driver only: 39.2 (GPS) I measured twice going in opposite directions. Each time the max was 39.2 at ~5800 RPM (wherever the ECU starts cutting gas).
DC_Rager
Post subject: Re: What's your top speed? Posted: Mon Oct 31, 2016 7:45 am |
| Newbie |
Joined: Wed Jun 12, 2013 2:36 pm Posts: 20 Location: Lake Anna, VA
33 MPH with 409 & 2313 prop. I'm debating on switching to the 2419 prop. The thinking is that I'll lower my GPH burn rate (my first tank during the break in period was at around 6 GPH) by lowering my RPMs during waking boarding sessions and during normal cruising speeds, while slightly increasing the RPMs during wake surfing, which we do about 65% of the time. What do you guys think?
Other speeds/RPMs:
2900 RPM - 10.5 MPH, factory ballast, 360 lbs of lead in nose + 4 people & wedge down 3600 RPM - 20.0 MPH, empty ballast, 360 lbs of lead in nose + 4 people & wedge up 3700 RPM - 22.0 MPH, same set up 3900 RPM - 23.4 MPH, same set up 4800 RPM - 29.3 MPH, same set up
_________________ 2006 Tige 22i - Traded for A22 2013 Axis A22 - Sold 2017 Axis T23, 6.0L 409, 2313 Prop, 360 lbs of lead until break in
Users browsing this forum: No registered users and 17 guests |
