It is currently Thu Sep 03, 2026 7:50 pm
 Post subject: Ballast pump?
PostPosted: Mon Sep 19, 2016 8:10 pm
Can someone tell me what pump I need for a 2011 A22? I want to keep one as a backup in case I have a failure on the water. Thanks
 Post subject: Re: Ballast pump?
PostPosted: Mon Sep 19, 2016 8:24 pm
Pirahna shurflo 800 model 357-116-10 just ordered 2 off ebay for $37 a piece shipped.
PostPosted: Mon Sep 19, 2016 8:33 pm
You can get the piranha 1100's. The cartridge is the same and you can save the housings in case you ever want to upgrade to larger hose.
PostPosted: Mon Sep 19, 2016 8:58 pm
I didnt realize that the cartridges were the same when i ordered my 800's. Wonder how much faster the 1100's would be while still utilizing the stock 3/4 hose?
PostPosted: Mon Sep 19, 2016 9:16 pm
Mine seemed slightly faster but I think it was just because it was newer. I think the only difference is the larger outlet size. The inlet size is the same as the 800's 3/4".
Also, here are the factory quick connects.
http://www.performanceplusconnection.co ... 16_14_10PK
Put the proper end on the spare pump and you can literally swap it out while on the water in under a minute. Once your day is done another 5 minutes to clean up the wiring a bit, zip tie etc...
PostPosted: Tue Sep 20, 2016 8:29 pm
Thanks guys!
Users browsing this forum: No registered users and 81 guests
