It is currently Tue Sep 09, 2025 7:40 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: T22/T23 owners: anyone plumbed in supplemental bow balla
PostPosted: Thu Sep 01, 2016 2:48 pm
Pics?
PostPosted: Thu Sep 01, 2016 3:59 pm
Prion wrote:
Pics?
Not a one, unfortunately. Have been doing all work in the dark with a headlamp before and after work.
PostPosted: Fri Sep 02, 2016 9:21 am
OK no pics of the pump, but you get the idea on the rest of the system:
PostPosted: Sun Sep 04, 2016 8:35 pm
shawndoggy wrote:
OK so I went ahead and did this. I added a new through-hull/ball valve in the center bilge (kept the T handle intact so I can still drain there).
You drilled a new hole through your hull? Man that sounds scary. Did you remove the floor panel or just do everything through the small round "hatch?"
Can't wait to hear how it goes. I'd love to have a pump setup like you describe. It takes a long time to fill with the extra triangle bag with a pump thrown over the side.
PostPosted: Sun Sep 04, 2016 10:27 pm
Yep, new through hull. Drill from the bottom, not the top. It's a pretty sweet adrenaline rush drilling a hole in the bottom of a perfectly good boat. Like hitting the meth pipe without the annoying loss of teeth.
Pump system worked out awesome. I was really happy with it. easy to set up. Just lay out the bag and connect the hose. Flip the switch and we're filling. No waiting with the stupid over the side pump anymore. Loved it!
PostPosted: Sun May 21, 2017 3:00 pm
Shawn, did you run your power source straight off of the battery?
PostPosted: Tue May 23, 2017 6:23 am
No -- it's from a fuse block that's attached to my switch. Don't want to accidentally turn on the pump with the battery switch shut down.
PostPosted: Tue May 23, 2017 9:20 am
Shawn, I'm doing the same project in my A20 (be thankful you have recessed panels in your bow). Where did you get those quick connect plugs? I have not seen anything like that.
________
PostPosted: Tue May 23, 2017 9:21 am
Also, PeterMcRae, where does your fill/drain line enter your bow? Any pics of the bow plumbing?
________
PostPosted: Tue May 23, 2017 1:34 pm
Which plugs? Everything is from wakemakers other than the dummy plug that I put in when not in use, which is one of the plugs that Malibu ships a plug and play boat with.
Users browsing this forum: No registered users and 173 guests
