It is currently Sun Feb 15, 2026 12:07 pm
 Post subject: How many bilge pumps in T22?
PostPosted: Tue Jul 19, 2016 4:13 am
Having a bit of an issue with my bilge pump. It seemed to be air locked but I removed it and got it going. Based on the toggle switch I assume we have 2 pumps; rear and center. I can only locate the rear one. Are there 2 pumps? Exactly where is the 2nd one?
 Post subject: Re: How many bilge pumps in T22?
PostPosted: Tue Jul 19, 2016 1:07 pm
47 views and no one knows. I'm sure AJWest will have the right answer.
PostPosted: Tue Jul 19, 2016 1:16 pm
Open up the little round hatch next to the drivers seat on the floor. It sits in there next to your t-handle drain. It has an angled screen fitting on it. I can't see mine due to the other ballast hoses, but it's down there and you can easily grab it with your hands. To remove, you may have to remove some of the ballast hoses.
2015 T23 - Sold
2018 ???
PostPosted: Tue Jul 19, 2016 1:27 pm
Only 1 rear pump on my 14 T22. No toggle for front bilge.
PostPosted: Tue Jul 19, 2016 4:59 pm
I thought that's where it would be but all I see there are the round ballast pumps.
PostPosted: Tue Jul 19, 2016 10:23 pm
Hmm. How many thru-hull fittings do you have on the starboard side by the helm? My center bilge discharges there. If you flip the switch to center bilge, does it sound like a pump turns on? I can hear mine with the cover off that access hole.
2015 T23 - Sold
2018 ???
PostPosted: Wed Jul 20, 2016 3:18 am
When I switch the center bilge my rear pump turns on. I thought before the dealer replaced my cracked dash that I could hear center and rear bilge pumps but never paid close attention to it. Now I only hear the rear pump on the center toggle position which makes me wonder if something else was left disconnected. Guess I'm playing a little more "find n seek".
Thanks for the help
PostPosted: Wed Jul 20, 2016 7:53 am
I have a 2014 T22 and always get water in the center bilge. I thought my switch only has on and off, not a 3 way. The center bilge never drains unless I take out the t-handle, so I just assumed that it only has the one pump in the rear...which is always bone dry.
2018 T22
PostPosted: Sat Oct 15, 2016 5:38 pm
it has a little bilge pump under the center round hatch. its a tiny little thing looks like a plastic torpedo. or something that belongs in a fish tank. mine keeps needing a prime and does not work well
