It is currently Sun Oct 25, 2026 1:17 pm
 Post subject: Trailer Rim size
PostPosted: Mon Jul 27, 2015 6:36 pm
Hello,
Got a 2012 axis a22 vandall with the tricked out trailer XD rockstar rims.
Wrecked a rim and need to get a replacement. I know the tire size but any idea of what bolt pattern or size I need To order a new rim? I called tire rack but I guess there are multiple bolt patterns and idk what I have.
Thanks.
 Post subject: Re: Trailer Rim size
PostPosted: Mon Jul 27, 2015 6:44 pm
The tire size should tell you the rim size. As far as bolt pattern, someone else may be able to help you with that. I think the rockstar rims are typically 20". So the tire should say something like 160/50 R20. The 160 is the tread width, the 50 is the heigth, and the 20 is the diameter of the rim. My numbers are not representative of the trailer wheel. It is just a guess at what they may be.
PostPosted: Mon Jul 27, 2015 7:27 pm
I purchased this wheel to add the Rockstar spare to the tricked out trailer. It has two bolt patterns drilled but has the correct 5 lug pattern and backspacing. The tire needed is a 255/45/18.
XD-Series Rockstar XD-Series775 Matte Black Wheel (18x9"/5x114.3mm) https://www.amazon.com/dp/B0025KUZ6W/re ... Ovb7RZPTS6
PostPosted: Mon Jul 27, 2015 8:23 pm
Bhowell yes I got 18 those are the exact ones thanks for the help.
I knew the tire size but that didn't help with the rim and bolt pattern and offset spacing
PostPosted: Tue Jul 28, 2015 7:46 am
took a look at your link and those are not available, but found these on amazon.
do you know if the rims have a offset? i see these have a little different part number but look about the same size and bolt pattern..
http://www.amazon.com/XD-KMC-Wheels-Roc ... KMC+Wheels
PostPosted: Tue Jul 28, 2015 8:30 am
From everything I can tell, that is the correct wheel. You could call Boatmate to confirm. The spacing is the most important point as Rockstar is now putting dual bolt patterns in most wheels to allow for more applications for the wheel. Since I couldn't find the single drilled 18x9"/5x114.3mm, I ordered a dual drilled (the one I linked to). I actually had a flat this past weekend and had to put it on and it fit just right.
PostPosted: Tue Jul 28, 2015 9:40 am
Thanks for the info.
PostPosted: Wed Jul 29, 2015 11:02 am
That should be the correct wheel. ^ If you were close to TN, I could hook you up. We deal with XD's every day.
PostPosted: Fri Jul 31, 2015 6:47 am
Thanks for the offer, Madison wi so not close to TN.
I got one locally for 210.00 but had to go with a rim that's multi pattern. Won't be able to tell once the center cap is on that it has more holes then the other rims.
PostPosted: Fri Jul 31, 2015 6:49 am
The one I posted to on Amazon I found for the record has no holes in the rim. It is a blank. I checked the part number with the manufacturer and they said that model has no stamped holes that it needs to be sent in and stamped. Or taken somewhere and cut to make it fit on whatever you want.
