It is currently Sun Oct 25, 2026 9:17 am
 Post subject: Toggle switch
PostPosted: Mon Jun 01, 2015 2:32 pm
My center ballast quit working.
No light on the toggle switch and no sound from the ballast pump.
Ideas or suggestions...?
Could it be as easy as just replacing the toggle switch...?
Thx
Bama Axis
 Post subject: Re: Toggle switch
PostPosted: Mon Jun 01, 2015 2:53 pm
Fuse?
PostPosted: Tue Jun 02, 2015 12:13 am
Check to see if any of the wires maybe vibrated loose on the back of the toggle switch? Check to see if u have a constant power going to the switch? If you do it could b the switch. For sure check those after you checked the breaker and or fuse first.
PostPosted: Sat Jun 06, 2015 9:46 pm
Haven't checked power to switch yet. Breaker was thrown. Pushed it back in and nothing..... No light on switch and no sound from pump. Dealer said ballast pump may have gone bad.
Later that day when heading back in my son hit the drain and it started pumping water out.
Will try to trouble shoot it more Sunday and have a little more info.
Bama Axis
PostPosted: Mon Jul 27, 2015 9:35 am
What was the outcome? I think I'm having the same issue with my rear port side hard ballast
PostPosted: Mon Jul 27, 2015 4:59 pm
I have had this issue. I tested the pump by swapping the wires with one that was working. It ran fine. Turned out to be wiring harness in dash. Look behind the toggle board and you'll see all the wires. Mine apparently wiggled loose and I just pressed it Back in and it's been good since.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 45 guests
