It is currently Sat Oct 24, 2026 4:49 pm
 Post subject: Impeller part/source 2015 PCM 350 T22
PostPosted: Sun Aug 21, 2016 8:07 am
Trying to figure out what I need. Couldn't find a thread on it.
Any tips/tricks for a newbie doing this work?
 Post subject: Re: Impeller part/source 2015 PCM 350 T22
PostPosted: Sun Aug 21, 2016 8:46 am
Impeller puller works easiest but I've done it without. Here's the part you'll need.
http://www.bakesonline.com/detail.aspx?ID=276
PostPosted: Sun Aug 21, 2016 8:49 am
I had looked at Bakes prior to posting.
I don't have an Indmar motor, is this still the right part?
Here's the puller I have. It works well as long as you have it in all the way.
http://www.bakesonline.com/detail.aspx?ID=1244
PostPosted: Sun Aug 21, 2016 10:52 am
Use a zip-tie around the new impeller when installing.
PostPosted: Sun Aug 21, 2016 12:59 pm
http://www.crusaderengines.com/wp-conte ... 032-14.pdf pg.41
part # RP061018
http://www.nautiqueparts.com/impellerin ... npump.aspx
PostPosted: Sun Aug 21, 2016 1:04 pm
yes same part as the indmar impeller. I just changed my pcm impeller. I usually use two screw drivers and pop the impeller out. if that doesn't work i start it with the screw drivers and pull it out with needle nose pliers. I'm sure the puller is easier but usually I can change the impeller in 15 min with the method described above.
PostPosted: Sun Aug 21, 2016 6:25 pm
is the crusader setup different than the PCM EX343? I never used a puller with that setup on my MB...
PostPosted: Sun Aug 21, 2016 6:30 pm
huh, yep it is different than the EX343.
