It is currently Tue Nov 11, 2025 2:44 am
[ 9 posts ] |
NWilly
Post subject: Impeller part/source 2015 PCM 350 T22 Posted: Sun Aug 21, 2016 8:07 am |
Trying to figure out what I need. Couldn't find a thread on it.
Any tips/tricks for a newbie doing this work?
get_sum
Post subject: Re: Impeller part/source 2015 PCM 350 T22 Posted: Sun Aug 21, 2016 8:46 am |
Joined: Fri Aug 17, 2012 1:18 pm Posts: 435 Location: OKC
NWilly
Post subject: Re: Impeller part/source 2015 PCM 350 T22 Posted: Sun Aug 21, 2016 8:49 am |
I had looked at Bakes prior to posting.
I don't have an Indmar motor, is this still the right part?
get_sum
AJWest
Post subject: Re: Impeller part/source 2015 PCM 350 T22 Posted: Sun Aug 21, 2016 10:52 am |
Use a zip-tie around the new impeller when installing.
simo47
Post subject: Re: Impeller part/source 2015 PCM 350 T22 Posted: Sun Aug 21, 2016 12:59 pm |
Joined: Mon Sep 14, 2015 2:10 pm Posts: 96 Location: Cincinnati
elc
Post subject: Re: Impeller part/source 2015 PCM 350 T22 Posted: Sun Aug 21, 2016 1:04 pm |
Joined: Tue Apr 27, 2010 11:31 am Posts: 327 Location: Anaheim hills, ca
yes same part as the indmar impeller. I just changed my pcm impeller. I usually use two screw drivers and pop the impeller out. if that doesn't work i start it with the screw drivers and pull it out with needle nose pliers. I'm sure the puller is easier but usually I can change the impeller in 15 min with the method described above.
shawndoggy
Post subject: Re: Impeller part/source 2015 PCM 350 T22 Posted: Sun Aug 21, 2016 6:25 pm |
is the crusader setup different than the PCM EX343? I never used a puller with that setup on my MB...
shawndoggy
Post subject: Re: Impeller part/source 2015 PCM 350 T22 Posted: Sun Aug 21, 2016 6:30 pm |
huh, yep it is different than the EX343.
[ 9 posts ] |
Users browsing this forum: No registered users and 45 guests |
