It is currently Mon Nov 10, 2025 11:28 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: 2012 Axis Tower
PostPosted: Thu Jun 21, 2012 8:15 am
Are you using the standard bolts or the quick release knobs like in the picture nasty posted? Mine has the quick release knobs and you can only get them hand tight, with the lower 2 loose you have quite a bit of movement in the upright so lining up the holes has never really been a problem for me. I just make sure to get all 8 going before I try to tighten any of them. It would take a lot to strip out the holes by hand only using the rubber coated knobs.
 Post subject: Re: 2012 Axis Tower
PostPosted: Thu Jun 21, 2012 8:44 am
Yes we have the quick release knobs. I guess the problem with lining up the holes is holding the tower in place while doing so. Remember I have the REV410's on the tower. (approx 100 lbs). If I didnt have that weight on the tower it would be easy. One person trying to do it is really hard.
Bama Axis
PostPosted: Thu Jun 21, 2012 9:18 pm
Hehe somehow I kinda wish I had your problem, my 2 rev10's slide right off and it breaks down easy but I find myself wanting more
PostPosted: Thu Jun 21, 2012 11:18 pm
We are actually getting better at breaking it down and putting it back up. I have got to say that I love the REV410's. You can hear them all over the lake. My son has no problem at all hearing them while he is riding.
I actually broke it down and put it back up by myself the other day but it was a hand full. I keep using tips from members here and keep trying some home grown engineering techniques.
Bama Axis
PostPosted: Fri Jun 22, 2012 9:57 am
I use Walter's technique and it's been very efficient for me!
Zak
PostPosted: Thu Jul 26, 2012 2:03 pm
Bama, do you have pictures of your jack system yet? I plan to make one as well and want to see if you have any good ideas I should steal before I start :D
PostPosted: Thu Jul 26, 2012 2:59 pm
Yes, I will try to post this evening or tomorrow.
Bama Axis
PostPosted: Thu Jul 26, 2012 9:39 pm
Dave.Mishchenko wrote:
I had to retap one of the holes on my tower and it was 1/2 - 13NC.
Thanks Dave
PostPosted: Fri Jul 27, 2012 9:51 am
I am going to attempt to post all of the pics on my jack system. It is not yet finished but you will get the idea.
In the pictures you will see the jack which I purchased at wally world.
You will see the base that I am going to mount it to. I used a 2x12 about 2 feet long to help distribute the weight across the floor. I took a router and made a foot print for the jack to sit in. I am in the process of drilling holes in the jack footing so I can secure it to the wood. I highly recommend this as the jack sometimes has the tendency to kick out to one side if your brace up to the tower is not 100% straight.
You will see the brace that I use. I am using a 2x4 with a cutout on the top for the tower to rest on. It also has a hole in the bottom for the jack to go into. Pictures will help illustrate this.
I use a 2x4 to put all the way across through the top cutouts on the tower arms. Once completed all of the pieces will be covered in carpet to help prevent from any accidental mishaps. I hook up the jack system and lower to the 2x4 brace and thats it.
Update......This still is not low enough for me to get it into storage and I am forced to lower the tower to the second cutout on the tower arms. I am in search of a jack that has a range somewhere in the 12"-15" range. This jack only has a range of about 7".
Attempting to update pics shortly.
Bama Axis
PostPosted: Fri Jul 27, 2012 10:15 am
A few pics of my jack system. Will post a couple more.
File comment: Brace going in place. Hole is about an inch deep. Helps prevent the brace from slipping off the jack when in use.
File comment: Hole in bottom of brace for jack to rest in.
File comment: Made a footprint on the 2x12 for the jack to sit in. In process of drilling holes so I can secure the jack to the wood to prevent it from kicking out to the side when in use. Has a tendency to do that if brace is not 100% straight.
Bama Axis
