It is currently Fri Nov 07, 2025 10:45 am
kohlieo
Post subject: Re: Ballast Drain Posted: Sat Jul 14, 2012 10:05 pm |
so I put the vent line of the pnp front bag up higher with a vented loop in it which stopped the draining into the center tank. Just letting you guys know. I'll try to throw up a pic next time I go under the dash.
_________________ 2011 Axis A22 Vandall Edition!!!
Ferral
Post subject: Re: Ballast Drain Posted: Tue Dec 04, 2012 12:16 am |
I solved that same problem by adding an extra thru-hull and eliminating the y. Now when I vent, I know if its my front, center, or both
Users browsing this forum: No registered users and 38 guests |
