It is currently Fri Nov 21, 2025 8:03 am
 Post subject: Which Wetsounds set up to go with for A-20
PostPosted: Mon Jul 02, 2012 12:18 pm
I'm trying to decide which set up to go with for my A-20. My hang up is the tower width. Will I be able to fit the Rev 3 some with the Rev 10's? I don't want the tower to look too cluttered. I believe the tower measures about 57" across. I might also go with twin 410's. Is there a benefit in sound quality between these set up's?
 Post subject: Re: Which Wetsounds set up to go with for A-20
PostPosted: Mon Jul 02, 2012 6:15 pm
I have an A22 and have two of the 410's on the tower and it really sounds great. Not sure about any other set up but will tell you that you can hear the 410's a mile away. Very pleased with my WetSounds system.
Bama Axis
PostPosted: Mon Jul 02, 2012 7:49 pm
I have pro 60's and all I cared about was being able to hear the music while riding and they do that. Not the loudest, can't hear it a mile away but can hear the music very clear and clean
PostPosted: Mon Jul 02, 2012 9:50 pm
Can you post a picture of your set up?
PostPosted: Mon Jul 02, 2012 10:19 pm
Check out nastyA20's rev 3some
PostPosted: Tue Jul 03, 2012 11:33 am
That's my A20- You'll have to redrill holes with either setup (2x 410's or rev10's and 410). Easy install if you have a helper. I'm about 5' 10" and my head will hit the speakers. Just gotta be careful of them.
I have a new rule with spray sun lotion. Do it down wind from speakers!!! That stuff gets on the stainless grills and is tough to get off. I'd also recommend some speakersox or covers for them.
I'm not crazy about the quick disconnect's for the price, and I wish Wetsounds would have put a rubber gasket to protect tower finish and clamp. They are working on this and hopefully will provide it free for customers. I used some garage door black foam liner cut to shape.
As far as sound goes, you won't be disappointed in them! Provide them with RMS or higher (preferred) watts and they'll sound great!
Msg me if you have any questions.
PostPosted: Tue Jul 03, 2012 1:47 pm
Bama Axis
PostPosted: Tue Jul 03, 2012 7:57 pm
What is everyone using to power their system? I've decided to get the 3 some with Rev 10's and will be running a JL audio W3 12" sub. Anyone recommend what I should get to power them? I'll be sticking with Wetsounds for my amp. Will the HT6 be sufficient to run everything?
PostPosted: Tue Jul 03, 2012 8:44 pm
Bama- The grills and screw mounts for speaker cover look like 485's
I'm running the arc audio 300.2 for rev410 and arc 300.4 for rev10's.
PostPosted: Tue Jul 03, 2012 9:08 pm
Do a syn2 and a syn4 if going with Wetsounds. I have no idea when the Sinister series will be out, but the specs look awesome.
I'd give them a call- I've always had good experiences with them with help.
