It is currently Thu Nov 13, 2025 12:58 pm
 Post subject: New ballast bags
PostPosted: Sat May 19, 2012 7:33 am
My wife is awsome, she just surprised me with some ballast bags from board stop. Rear 750's I'm on my way home to try to install them how long does it take on a 2011?
 Post subject: Re: New ballast bags
PostPosted: Sat May 19, 2012 8:49 am
took me 20 minutes. hated how slow they were. disconnected them. now i am buying a ballast pump to use. i may try some setups like these guys have on here. i am considering getting the reversible pumps that mastercraft uses in their boats and having their own dedicated fill, drain, and vent.
Gibby
2011 A22 Vandall
PostPosted: Sat May 19, 2012 10:57 am
The 750's are a perfect match IMO for the Axis...unless you're just that good you need the 1100's lol and the bigger engine.
PostPosted: Sat May 19, 2012 11:08 am
I really want them to help my surf wave.
PostPosted: Sat May 19, 2012 12:49 pm
AJ how are your bags hooked up?
Gibby
2011 A22 Vandall
PostPosted: Sun May 20, 2012 8:19 pm
Tried them out today and the wake was great, I did find out that my front ballast switch is backwards on the dash. Is that something I can fix myself or should it go to the dealer? Also does anyone have trouble when loading the boat the rub rail gets white marks on it from the guide poles and they don't want to come off any ideas?
PostPosted: Sun May 20, 2012 9:53 pm
My rub rails also get that stuff on them, and I can't seem to get it off either. Someone told me to use acetone and wipe it off then dry it fast, I haven't had the nerve to try it yet, that stuff is pretty harsh. On the switch you can probably just look under the dash and switch the wires.
PostPosted: Sun May 20, 2012 10:47 pm
Aceton works really well but also SOS pads and water work as good.
PostPosted: Mon May 21, 2012 7:22 am
Anyone tried Magic Erasers? I got these marks this weekend as well.
PostPosted: Mon May 21, 2012 7:35 am
The green can of brake clean works for the marks too.
Users browsing this forum: Google Adsense [Bot] and 67 guests
