It is currently Sun Aug 24, 2025 12:02 am
 Post subject: Fix for actuators hitting D rings.
PostPosted: Fri Jul 20, 2018 5:21 pm
1/4" shim behind actuator bracket. Moves gate 1/4" from swim platform (my gates were already about 1/4" away so now they are about 1/2" away) and clears D ring without jeopardizing performance. So unless you want to get into gel work and moving the D rings this would be the way to go. Either way warranty will cover it. This is for 2018 T22s.ImageImage
 Post subject: Re: Fix for actuators hitting D rings.
PostPosted: Fri Jul 20, 2018 6:20 pm
Can you explain why you need this done?
PostPosted: Fri Jul 20, 2018 7:47 pm
On 2018 T22s when the surfgate is opened the actuator hits the D-Ring and puts a lot of pressure on the plastic actuator bracket causing them to break. So unless you move the D-Ring over and get into gel work this is what boulder boats and Malibu came up with.
PostPosted: Sat Jul 21, 2018 3:59 am
My boat had 3 of those shims each side from the factory. Surprised they didn't use any on the 18s. Guess different actuators
PostPosted: Sat Jul 21, 2018 9:05 am
Apparently at some point in production, Malibu caught it. The later build '18 T22's have the d-rings located further outboard towards the surfgate hinges so they don't have the interference issue.
2018 T22
PostPosted: Sat Jul 21, 2018 9:55 am
Steve, any chance you could snap a photo that has both the actuator and the D-ring for reference? I can't see mine hitting (maybe mine has the updated location), but I want to make sure.
2018 T22
PostPosted: Mon Jul 30, 2018 8:50 pm
They corrected the issue at some point in April from what I can tell.
You can see in mine the drings are farther outside the issues are when these are closer to the actuator, OK can't post it as is to big
First Boat - Tiny AlumaCraft w/ 8hp Johnson
---- Nothing -----
Last Boat - 2016 Four Winns H180RS --- RIP 1/25/2018
New Boat - 2018 Axis T22!!!!!!!!!!!!!!!
Users browsing this forum: No registered users and 130 guests
