It is currently Fri Nov 14, 2025 7:40 pm
 Post subject: 2017 A24 wants to go hard left
PostPosted: Mon Apr 10, 2017 12:39 pm
Just got our new A24, loving everything about it so far. There are a couple goofy things but we are working through it. We took the boat out yesterday for the second time. Just got done with the 5 hour break in period. So I am traveling about 20-30 mph and I have a hand on the wheel and I can feel the boat want to make a hard left. So out of curiosity, I let go of the wheel and the boat aggressively turns hard left. I don't normally drive without hands on the wheel but lets be honest here. At times, on a boat, your hands come off the wheel. I read that it could be from prop thrust? Anyone else have this issue?
Thanks!!
Trevor
2017 A24
 Post subject: Re: 2017 A24 wants to go hard left
PostPosted: Mon Apr 10, 2017 1:04 pm
Rudder just needs to be adjusted. There is a little adjustment piece on the back of it. First make sure it's sitting dead center.
PostPosted: Mon Apr 10, 2017 7:57 pm
ok, Thank you!
PostPosted: Tue Apr 11, 2017 5:39 am
Keep one thing in mind though. There will always be some pull to the left even after the rudder is adjusted. Like you mentioned earlier, prop torque.
PostPosted: Tue Apr 11, 2017 1:37 pm
Thanks!!
Trevor
2017 A24
I had the same thing happened with my 2015 A22. They adjusted the little piece on the rudder but didn't seam to help much. I kept complaining because my previous Axis drove straight as an arrow. I think they finally had to realign something.
PostPosted: Wed Apr 12, 2017 10:48 am
spoke to the dealer yesterday, they don't seem to be worried about it. They say its pretty common for the boats to go left. Seems kinda sketchy to me.
PostPosted: Wed Apr 12, 2017 3:14 pm
Mine pulls left
PostPosted: Tue Apr 18, 2017 6:49 am
This is typical for an inboard boat v-drive or DD. True direct drives typically pulled even harder, this is to help with steering feedback while tracking a straight line. That adjustment tab can be dead straight or even counter adjusted to change the feel of the steering.
Ridebutter Wakeboard School
Cove Wakesurfers
PostPosted: Tue Apr 18, 2017 4:28 pm
I went out yesterday on a 2017 A24 and there was zero pull to either side. My A20 doesn't pull either.
Sent from my SM-N910V using Tapatalk
PostPosted: Thu Apr 20, 2017 9:45 pm
Ditto, and my A20 0 pull
