It is currently Tue Oct 21, 2025 1:40 am
 Post subject: Flyhigh and Sumo triangle bags.
PostPosted: Mon Mar 27, 2017 2:22 pm
☆☆BOTH SOLD☆☆
 Post subject: Re: Flyhigh and Sumo triangle bags.
PostPosted: Fri Apr 07, 2017 4:35 pm
so the fly high sac with fit directly in my t23 plug n play system
PostPosted: Fri Apr 07, 2017 4:40 pm
Yes. Fill and vent lines on top of bag and drain is at the bottom in the middle. Your hoses should all be long enough to plug right in.
PostPosted: Sun Apr 30, 2017 10:38 am
will do the flyhigh for $100 shipped.
PostPosted: Sun Jun 25, 2017 9:59 am
Bump, sumo still for sale $100
PostPosted: Thu Jul 13, 2017 11:46 pm
Did you notice a big difference going from the Fly High PNP sac to the Wakemakers PNP sac?
PostPosted: Fri Jul 14, 2017 11:06 am
Not really, space is space and you can only get 400lbs under those cushions. The big difference is just the bag itself. The WM bag is a direct fit tapered triangle bag that fills to capacity with no excess bag material. They placed the fill and vent ports at the top/tip of the bag allowing them to be up in the hollow spot of the nose area, not allowing cushions to get pushed up. The flyhigh has close to the same fitting placements you just have a lot off excess bag. Can't really go wrong with either. The only reason I switched is because I got the WM bag 10% over dealer cost.
PostPosted: Fri Jul 14, 2017 2:48 pm
Cool, thanks for the info. No real need to switch then I guess. We surf a lot so we usually end up with a triangle on top of the seat cushions anyway.
