It is currently Wed Sep 10, 2025 2:25 pm
 Post subject: Busted knock sensor stud
PostPosted: Tue Nov 15, 2016 9:12 pm
Where can I buy a knock sensor/block plug for my 2011 a22 with 400hp 6.2 motor? Busted one winterizing it today. Just need the plug/stud, sensor itself is fine.
 Post subject: Re: Busted knock sensor stud
PostPosted: Wed Nov 16, 2016 5:20 am
If it's a standard gm plug which I would say it probably is most part stores should have it
PostPosted: Wed Nov 16, 2016 8:32 pm
Check bakesonline.com.
PostPosted: Wed Nov 16, 2016 9:06 pm
If you don't mind me asking, how does this happen? Maybe you can help me keep from doing the same.
PostPosted: Wed Nov 16, 2016 9:57 pm
Go to your closest gm dealer and ask for one for a camaro SS, should be the same engine
PostPosted: Thu Nov 17, 2016 9:24 am
Confused... was the 2011 not a half closed system? I would not expect to have to pull the knock sensor.
Users browsing this forum: No registered users and 101 guests
