It is currently Wed Sep 10, 2025 11:57 am
 Post subject: Fuel/Water Separator or Fuel Filter?
PostPosted: Fri Oct 07, 2016 11:25 am
2014 T22.
Is there a fuel filter that you are supposed to replace? My Malibu had a fuel/water separator I replaced every other year. There is nothing on the motor (330 Monsoon), just want to make sure I'm not skipping maintenance I should be doing.
2018 T22
 Post subject: Re: Fuel/Water Separator or Fuel Filter?
PostPosted: Tue Oct 11, 2016 10:49 am
Anyone??
2018 T22
PostPosted: Wed Oct 12, 2016 9:57 am
Since no one else chimed in, I'll tell you what I've found so far. I think that the filter is basically a cartridge that goes over the pump, that is in the fuel tank. Some may have a spin-on fuel filter that looks like an oil filter but mine doesn't. I don't believe that they have the low pressure and high pressure (threaded type) in filters that we have become accustomed to. Here is an example of one.
http://www.nautiqueparts.com/fuelfilter-pcmfcc.aspx
This is for a PCM.
PostPosted: Thu Oct 13, 2016 8:44 am
This is for a PCM.
Hmmm ok. Since its in the tank I am assuming this is not something that is typically replaced as part of scheduled maintenance...
2018 T22
PostPosted: Thu Oct 13, 2016 10:29 am
From the manual
The frequency of draining the water or replacing the filter element is determined by the contamination level of the fuel. Replace the filter element at least once a year, or when a loss of power is noticed (whichever occurs first).
http://www.crusaderengines.com/wp-conte ... 032-14.pdf
pg 38
PostPosted: Sat Oct 15, 2016 5:21 pm
Raimie wrote:
2014 T22.
I asked about this at the marine store this engine probably has a high pressure fuel filter and you do not change it like a regular filter at least not every year like a canister.
PostPosted: Sun Oct 16, 2016 9:53 am
simo47 wrote:
From the manual
pg 38
2014's had Indmar
2018 T22
Users browsing this forum: No registered users and 89 guests
