It is currently Wed Sep 10, 2025 1:36 pm
 Post subject: Vent line for front pnp
PostPosted: Tue Aug 09, 2016 6:35 pm
Has anybody plumbed a vent line for the front bags? I get tons of air in mine and the burp valve is a pain to get to on my sumo 650. Where do you tap into for the vent line?
Sent from my SM-G920V using Tapatalk
 Post subject: Re: Vent line for front pnp
PostPosted: Tue Aug 09, 2016 6:36 pm
I've read the forums on the rear pnp but was curious if the front was different.
PostPosted: Tue Aug 09, 2016 7:57 pm
What year and boat do you have?
My boat came factory with a bow bag vent line and I thought they all did.
PostPosted: Tue Aug 09, 2016 7:58 pm
2016 t23...I have 2 drain lines and 1 fill line.
PostPosted: Tue Aug 09, 2016 8:20 pm
No, I've got a 2016 T23 too, unless it just wasn't installed you have 1 fill, 1 drain, and 1 vent.
How many holes do you have on the bow front right?
PostPosted: Tue Aug 09, 2016 8:33 pm
I don't think it was installed...the one in the top is the fill and I have 2 at the bottom of the bag...I would assume they wouldn't put a vent at the bottom of the bag
PostPosted: Tue Aug 09, 2016 8:41 pm
I have 5 holes on the front right of my bow
PostPosted: Tue Aug 09, 2016 8:44 pm
Well they definitely hooked that part up wrong, but you can't have 2 drains if you don't have 5 pumps. You've likely only got 4 as I can't see Axis drilling and installing an entirely extra pump. If your hoses aren't long enough, and the dealer installed it, take it back and have them do it right.
Your fill line (with the check valve) need to go on the lower left, your drain on the lower right (cause you're most likely to always have weight in the right with the driver tilting the bag that way), and your vent needs to go on top (cause air rises)
Take the 4 screws out of the sub panel, remove it, and look behind it. You'll see the 3 lines going into the bow area. Two will go below deck in the cutout back there and 1 will go up to the vent.
Your 5 holes are, Center Bilge, Center Drain, Center Vent, Bow Drain, Bow Vent. Unless for some odd reason one of those holes isn't hooked up to anything, but take your sub panel off and you'll be able to trace it out.
PostPosted: Tue Aug 09, 2016 8:48 pm
Awesome thanks for the info...I thought maybe they y'd off the bottom two valves so there were 2 drain spots...
PostPosted: Tue Aug 09, 2016 8:50 pm
They probably hooked my rear bags up wrong too because I have to burp all the air out of them and the fill line is connected to the top
Users browsing this forum: No registered users and 80 guests
