It is currently Thu Nov 13, 2025 2:24 pm
 Post subject: Factory 36qt Igloo vs 48qt Coleman
PostPosted: Sun Jul 24, 2016 9:34 am
Factory Igloo 36qt is $90-$100 from Axis. 48qt Cokeman $16.49 at Dicks Sporting Goods
The Coleman has a drain as well
 Post subject: Re: Factory 36qt Igloo vs 48qt Coleman
PostPosted: Sun Jul 24, 2016 9:37 am
Yep, I have a red coleman from Dick's. Matches the boat!
PostPosted: Sun Jul 24, 2016 4:46 pm
Does it fit under the seat with no problems?
PostPosted: Sun Jul 24, 2016 6:31 pm
Yes it does, it fits in the recess in the floor fine as well so it doesn't slide around.
PostPosted: Sun Jul 24, 2016 6:36 pm
It fits my 2014 A24. Can't confirm any others. People complain about the igloo cooler in the A22 so I seriously doubt it'll work in that due to seat cushion issues.
PostPosted: Mon Jul 25, 2016 8:48 am
But it doesn't have an Axis decal on it :P
PostPosted: Mon Jul 25, 2016 1:15 pm
The factory cooler in my 2015 A22 is incredibly poorly designed. After removing the cushion above the cooler and the square corner cushion, the cooler lid opens 20 degrees before hitting the fiberglass in the back. I can't imagine a larger cooler in the same space.
Peter
Boat: 2015 A22 - Icon 8's & sub - Fly High 550s & 950.
Tow: 2016 GMC Sierra Denali HD Duramax
PostPosted: Tue Jul 26, 2016 8:14 am
Anone know if it will fit in the '16 T23? I larger cooler would be nice and the stock one slides around a bit.
PostPosted: Tue Jul 26, 2016 9:01 am
Well I bought one yesterday, when I get my boat back Thursday, I'll let you know if it fits.
PostPosted: Tue Jul 26, 2016 10:39 pm
The 48qt. Coleman fits in the 2016 T23 without sliding around. If you remove the hinges on the cooler it makes it much easier to access.
