It is currently Thu Nov 13, 2025 10:06 am
 Post subject: Service Required
PostPosted: Sun Jul 24, 2016 1:00 pm
Boat has 109hrs on it. I changed the oil myself about 100hrs. It's now giving me a service engine required message and beeping. Is there a way to turn this off without taking to dealership?
 Post subject: Re: Service Required
PostPosted: Sun Jul 24, 2016 3:34 pm
Did you check the fault code?
PostPosted: Sun Jul 24, 2016 6:11 pm
Yes it shows nothing.
PostPosted: Sun Jul 24, 2016 8:21 pm
I had the same issue on mine. Initially PCM said there was a software update that fixed an issue with the water intake manifold temperature alarm threshold being set to low. It's not actually a problem, but annoying. There's a software update your dealer can do. I had them do it on mine, and took it out that same day and the alarm went off again.
Went out 2 more days and ran it hard, no alarms at all. Boat is back in the shop for the 20 hour service and they're working with PCM on it. I should have the boat back by Tuesday and I'll give an update.
PostPosted: Mon Jul 25, 2016 6:40 am
Pull the positives on the batteries overnight. This should reset the service required error. It will keep coming on if there is still a problem but it shouldn't return if it was a one time thing. If it does pop back up, immediately check the fault code.
I've heard that a couple of cold starts without seeing the error will reset it too but the battery disconnect worked for me.
PostPosted: Mon Jul 25, 2016 9:36 am
What code exactly were you seeing? I've seen these codes a few times and this weekend it was on longer and caused me to go into limp mode. I pulled the impeller and swam under to check the intake for debris. All was fine.
ECM: SPN 441 FMI 15
ECM: SPN 442 FMI 15 (5 times)
PostPosted: Mon Jul 25, 2016 10:38 am
http://dealer.pcmengines.com/assets/Att ... terial.pdf
PostPosted: Tue Jul 26, 2016 5:20 am
Also when the light first comes on the boat seams to temporarily lose power but picks right back up.
PostPosted: Tue Jul 26, 2016 7:48 am
I would try to read that code ASAP. Losing power points more towards a malfunctioning part than a bad sensor something.
Might look into buying one of these if you're a good drive from the dealership. It would help to figure out if you have a serious issue or more of an annoyance. They are about $600 though.
http://www.rinda.com/marine/marine.htm
PostPosted: Tue Jul 26, 2016 7:54 am
ECM: SPN 441 FMI 15
Pretty sure that's the error code the 2015 PCM engines were seeing before the software reflash. What year are you?
http://www.ambil-yam.co.il/files/pdf/PC ... manual.pdf
DTC 1416 - Exhaust Manifold Water Temperature (EMWT) Sensor 2 Higher Than Expected
Stage 1
SPN - 442; FMI - 15
