It is currently Sun Mar 29, 2026 6:13 pm
 Post subject: Lake Powell trip!!
PostPosted: Mon Jul 04, 2016 8:41 pm
We just got back from a week at Powell on the 16 t 22 and had some issues.
I blew 3 fuzes on the surfgate. I am lucky the dealership gave me extra.
My check engine light came on saying low oil pressure and checked the dipstick and it was under the add on the very bottom. I added two Quartz and went to almost full. I saw a lot of oil at the bottom of the boat.
Last it took a full throttle to surf at 11.2-11.8 with full ballast and 7 adults with high altitude it had a hard time keeping the cruise green light on.
Calling the dealer tomorrow!
 Post subject: Re: Lake Powell trip!!
PostPosted: Mon Jul 04, 2016 11:49 pm
Wow! That's a pretty terrible trip for a brand new boat. I spend a lot of time at Lake Powell (probably 26 days last year, 6 so far this year but 3 more trips planned.
Lake Powell is the LOWEST elevation I run at. I feel so free there. My boat can do tons there compared to reservoirs at 7000+ feet. That said, full ballast (3400 + wedge) and 7 adults is about all I can do for surfing even at Lake Powell with the 409 and a 12 pitch prop. Get used to it. If you wanted to go heavier, you should have bought the 450 engine. If you don't have a 12 pitch prop, you can get that and it will help you get more weight moving. But on a big lake like Powell, that's going to affect some mileage and top end speed.
The dealership should take care of the oil and surfgate issues. I just had my first surfgate issue at 155 hours. Kept getting stuck out. So I'll be at the dealership tomorrow too. Maybe I'll see you!
I can't believe how many people go to Powell in July. What a sweatfest. Come back at the end of September/early October and experience paradise.
PostPosted: Tue Jul 05, 2016 5:46 am
The surfgate needs bigger fuses. Had the same issue on my 16 T23. I also have the oil issues I've been told by Malibu and PCM that the boat will use oil while running under the heavy loads I run surfing and boarding. I just get a gallon of oil and check it each time before I go out and fill as needed. Boat now has 85 hours and I just started my 2nd gallon of oil.
PostPosted: Tue Jul 05, 2016 8:09 am
Powell is awesome we are going to try and get back in October. We had nice weather this trip too! The dealer said they are going to put a circuit breaker for the fuses hope that helps. The oil thing stinks but I am going to go out and buy some oil today!! Thanks for the tip!
PostPosted: Tue Jul 05, 2016 9:48 am
Terrible to have issues on a trip like that. A Powell trip is the trip of a lifetime for most. Lucky you are able to get back again.
PostPosted: Tue Jul 05, 2016 11:19 am
Was there oil in your bilge? Is this a brand new boat?
2015 T23 - Sold
2018 ???
PostPosted: Tue Jul 05, 2016 12:14 pm
I could see the motor burning oil, but what I would be concerned with is that you said you saw oil at the bottom of the boat. That is not normal.
PostPosted: Tue Jul 05, 2016 7:19 pm
Are they special kind of fuses for the surf gate? I need to probably get some because I am headed to Lake Powell in a few weeks. Need to make sure I'm prepared :)
Sent from my SM-G920V using Tapatalk
PostPosted: Tue Jul 05, 2016 7:30 pm
standard fuses. Get 50's or 60's the 2016 boats have 40's but the new surfgate actuators are causing them to blow.
PostPosted: Tue Jul 05, 2016 7:32 pm
That's good to know..I have a 16 t23. If I am prepared nothing can go wrong right?;)
Users browsing this forum: Google Adsense [Bot] and 63 guests
