It is currently Thu Sep 11, 2025 4:18 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: 2016 T23 prop
PostPosted: Sun Jul 03, 2016 6:02 am
steveA20 wrote:
The 2313 worked great but my RPM's at 23mph went to 4200. I tried the 2773 and it felt really close to the 2313 but my RPM's dropped back to 3900 at 23mph. The boat would still not plane out with 3k ballast plus wedge unless you start dumping the rears. I also burned 5 more gallons of gas that day with the same setup with the 2313.
My setup.
Stock 800
Rear 550's
Flyhigh 1000lb triangle under bow cushions, prob holds 450
Sumo 450 on top of bow cushions.
100 lbs lead to move around.
So the 2773 wouldn't plane out unless you drained some of the rears but you decided to keep it anyways? Just cause the RPM was lower? I'd like to be able to plane out and my RPM be around 4k at 23.
PostPosted: Sun Jul 03, 2016 8:09 am
80AMT23 wrote:
My setup.
Stock 800
Rear 550's
Only with the wedge down it won't plane out. With 3k ballast it does great popping out and getting to 23mph. I kept the prop because it felt stronger than the 2249 and I didn't want to drop to a 12 pitch because of the big jump in RPM's. I settled with the 2773.
