It is currently Wed Sep 10, 2025 10:14 pm
 Post subject: Re: kicker radio
PostPosted: Wed Jun 15, 2016 4:39 pm
bwirk2000 wrote:
nitrous1 wrote:
You need to turn volume knob so the volume bar shows on the display, then push volume knob and bar will change to zone 2, then you can adjust. That one knob does to many things! And sound pack 1,2,3 all use the kmc 20 head unit it's nice but you can't see it where it is mounted.
Agree that the mounting/screen visibility is poor. But thanks for the knob info. I had no idea and I actually read most of the kicker manual.
Make sure you turn knob first to bring up volume bar on the screen before you push the knob, if you don't it will go to a different menu. I have no idea why they put the head unit down there when they did the dash redesign, it needed to be up high.
PostPosted: Wed Jun 15, 2016 4:50 pm
mmclimber wrote:
thanks all. it is hard to tell what volume control is being adjusted since I can't typically see the screen... Needs more shade I guess. I will try it out tonight... Willing to bet the 1 tap, 2 tap, 3 tap thing is the solution.
Although i would be interested to know how you adjust the gains... I looked online and learned you are simply adjusting the amps to the most efficient level. I looked at the amps under the console on the passenger side and they don't have any nobs on them like the guys on youtube showing how to do this.
Do I need to take it to a stereo place... that is next i guess.
You have to take the cover off the end at the top and there is a rubber strip you lift up and all the gains are under those, you will need a mirror and small flat screwdriver (may be easier to unscrew the amp board to get at settings). If you have never set up your amps before, wet sounds has a nice set of instructions for setting up the Ws420 that will work for anything with a equalizer , just google "ws420 settings" and it should come up
Users browsing this forum: No registered users and 124 guests
