It is currently Thu Sep 11, 2025 4:15 pm
 Post subject: Please measure your bimini for me...
PostPosted: Wed Sep 09, 2015 5:32 pm
I am stuck at work for 2 more days and really need to order a bimini boot for my A22. Mine tore and blew completely off when I towed it home in a storm.
I am going to order an aftermarket boot for it because you cannot buy an Axis one without buying the entire bimini....
I do not want to make a mistake by guessing between the 91"-96" or the 97"-102". I am guessing the 97-102 will be fine but I want to double check. If someone can measure the outside distance of your bimini cover and let me know what it is. Thank you.
 Post subject: Re: Please measure your bimini for me...
PostPosted: Wed Sep 09, 2015 5:47 pm
The boot is 67" long. If you want it to turn 90 degrees downward on each end, I would get a 72". If Tapatalk would let me post a pic, I would to prove it.
PostPosted: Wed Sep 09, 2015 5:51 pm
PostPosted: Wed Sep 09, 2015 5:58 pm
that seems short, but thank you for measuring for me.
61-66
67-72
or 73-78 ?
I would rather it be a little big than a little snug
PostPosted: Wed Sep 09, 2015 6:02 pm
Okay, I ordered the 67-72. That should be perfect. Thank you for measuring for me. :D
PostPosted: Wed Sep 09, 2015 6:22 pm
The 67" - 72" will be perfect. I almost made the same mistake on my last boat till I measured. It is surprising how much shorter it is than the beam.
PostPosted: Wed Sep 09, 2015 6:25 pm
Okay, I ordered that one. Thank you very much. I am sure glad I did not guess... I would have been way off!!!!!
PostPosted: Tue Sep 15, 2015 5:32 pm
dezul wrote:
Got my cover in the mail yesterday, it was perfect size. Thank you again!!
PostPosted: Tue Sep 15, 2015 5:57 pm
Johnnydefacto wrote:
No problem. I am glad you asked before you bought it. I made that mistake with a Bimini before.
PostPosted: Tue Sep 15, 2015 8:33 pm
Yeah I would have ordered one way too big. Only bummer is I thought their would be straps attached to it just like every other bimini cover, but no biggie, I will just have to figure something out.
