It is currently Thu Sep 11, 2025 4:17 pm
 Post subject: Interior colors
PostPosted: Mon Aug 10, 2015 10:30 am
Still in the process of deciding on a boat, been trying to weed through threads on all the different forums and figure out whats right for me. Still torn between axis and moomba, but in the meantime I am working on trying to figure out which interior colors I want to go with. What have you guys found with grays vs whites and other colors. I am thinking the grays will probably get hotter in the sun but I feel like white will start to discolor sooner. Does the white get dirty or will it continue to look new if it is wiped down after every day on the water? Also have seen pictures of earlier axis boats where the white vinyl gets a red/pink discoloration when not in the sun... But after a few hours it goes aways... Then comes right back after its been out of the sun, has this issue been resolved? How about grays? Assuming they will look better longer. Will black accents get hot? Or do I not need to worry about it?
Would just like to hear what you guys have done with interior colors and what you would do differently next time.
Thanks,
Royce
 Post subject: Re: Interior colors
PostPosted: Mon Aug 10, 2015 11:08 am
Everything gets hot in the sun, The darker the grey the hotter it gets, I have Cement as my base and it only gets a little hotter than white, I have black accents and they burn you pretty good. I was on a 2016 with Flint as the base and it got hotter faster than the lighter colors but after 20 minutes in direct sun pretty much everything is scorching hot. If you wipe down the seats and keep them covered you should not have any problems with the white discoloring, I haven't after 2yrs and 170hrs.
PostPosted: Mon Aug 10, 2015 4:19 pm
Agree with mcmiller, go with the colours you like and maintain it, you'll be fine.
2012 Axis A20 Down Under
PostPosted: Mon Aug 10, 2015 4:30 pm
My interior is white and been in 5 summers in west Texas, still looks good, vinyl cleaner and conditioner every other time out
The attachment ImageUploadedByTapatalk1439245791.401577.jpg is no longer available
PostPosted: Mon Aug 10, 2015 8:17 pm
Get the colors you like. Some colors get hotter than others but I'd always go with the colors you like
2015 T23
PostPosted: Mon Aug 10, 2015 8:33 pm
Like everyone is saying, just get what you want. I have white and it still burns my feet if the boat is just baking in the sun...
2014 A22
PostPosted: Mon Aug 10, 2015 8:35 pm
Walter, do you hit your vinyl with a soft brush or anything when you are using the vinyl cleaner? Mine is clean from obvious marks but still slowly picking up a darker tint in high traffic areas like the rear seat. And I use vinyl sauce about every other time also
2014 A22
PostPosted: Mon Aug 10, 2015 9:45 pm
I usually just use a microfiber, but if it starts getting dirty I rub it with warm water and the same car wash soap I use on the outside and a white terry cloth towel and it cleans right up.
PostPosted: Tue Aug 11, 2015 6:37 am
[emoji106] thanks man. Will try the soap
2014 A22
PostPosted: Tue Aug 11, 2015 10:59 am
Thanks for the input guys. Have another question that I will ask here rather than starting a new thread, anyone know if the carpet on the T22/T23 that is between the seat and the floor is removeable? Whats under it and hows it attached? Hoping that its maybe just glued and could be torn off and stripped of the remaining adhesive.
Users browsing this forum: No registered users and 73 guests
