It is currently Thu Sep 11, 2025 3:13 pm
 Post subject: Pandora Playback
PostPosted: Mon Apr 20, 2015 8:39 pm
Greetings. Hooked up my Iphone 6plus to the usb adapter and the display reads no music when I have the Pandora app going. Went through the manual and tried to initiate the passenger control with the mode button and no response there. Any clues as to where I am going wrong? Just have the basic radio with no amps or tower set up. All input is appreciated.
 Post subject: Re: Pandora Playback
PostPosted: Tue Apr 21, 2015 4:21 am
It makes me wonder if the head unit will recognize the 6plus. It may be a compatibility issue. Do you have any friends with older iphone devices to try?
PostPosted: Tue Apr 21, 2015 6:41 am
Tried the old 3gs and same issue. What device do you play back through the usb?
PostPosted: Tue Apr 21, 2015 6:47 am
I have an iPhone 6 Plus with no problems playing iTunes or play lists off of my phone USB port or using Bluetooth. Check your phone settings and make sure the Pandora is playing through your phone speakers settings. Any chance you have Pandora set to play wirelessly through your home network and you did not change it when you got to the boat.
Jim Fuller
Lake Keowee, SC
2014 Axis A24
Boat Name: Who's Next
PostPosted: Tue Apr 21, 2015 7:08 am
The radio should be turned USB or AUX as its source. I can't remember which one it is. I typically use a thumbdrive with music on it.
PostPosted: Tue Apr 21, 2015 10:38 am
iphone + sony headunit = crapshoot
I intermittently have this issue. Try a different cable.
