It is currently Thu Nov 06, 2025 1:43 pm
 Post subject: Thru-hull fitting
PostPosted: Sun Nov 02, 2014 7:58 pm
So my boat came with 1 1/8" stainless steel thru hulls and I am planning on adding a separate vent line to my front bag and center tank. I am wondering if the wake makers fittings are visually the same to what malibu uses in the factory. Or would a place like west marine have them?
 Post subject: Re: Thru-hull fitting
PostPosted: Mon Nov 03, 2014 4:54 pm
The 1-1/8" stainless from Wakemakers will match Malibu OEM but I have t found the black Axis thru hull yet. It shouldn't be an expensive part to get from your dealer so I wouldn't have an issue ordering through them or maybe call Bakes, those guys are great people and very fair on price.
PostPosted: Mon Nov 03, 2014 6:00 pm
I ended up stopping by west marine just to see if there's matched before I ordered online. They ended up having the exact same ones that I had in my boat. I also decided to raise my anti siphone loop for the front bag. My loop was just above the floor, now it's right underneath the windshield. All in all, it was a fairly simple job. Here's how it came out.
PostPosted: Mon Nov 03, 2014 7:26 pm
Looks like a perfect match. I thought of changing my thru hulls for stainless as a winter mod project but I don't really know. I think the black look just fine with the Axis side badge and possibly the stainless so close to the black Axis badge would look a little "off"
PostPosted: Tue Nov 04, 2014 2:35 pm
I ordered mine directly from the manufacturer, much cheaper!
Haven't installed them as of yet ... still waiting on the absolute fix from Axis for the rear draining vents. They claim a loop is needed higher than the vent port (duh) ... we'll see. But I at least have the parts.
https://www.flow-rite.com/
PostPosted: Tue Nov 04, 2014 5:14 pm
Yea that's what I got but the SS version. West marine sells the flow-rite thru hulls. All are plastic but mine had the SS mushroom, they also had black and white.
I would upgrade if I had the plastic thru-hulls. I feel it makes the boat look more expensive haha.
My boat is funny though. It's a 12' that should have had 3/4" ballast tubing but liquid force or malibu decided to throw 1 1/8" hoses. Come to find out, the factory was probably low on the bigger fittings, I found a 3/4" T fitting in my rear drain that had excessive amounts of silicone to make up the difference. All my hard tanks had the 1 1/8" fittings though. I also have a different setup for my rear drains. My bags and tanks are both connected straight to the drain pump.
PostPosted: Tue Nov 04, 2014 6:24 pm
I think those black ones look much better than stainless would given your colors and Axis logo.
PostPosted: Tue Nov 04, 2014 6:51 pm
Thanks for your opinion...was thinking the same thing.
