It is currently Sun Nov 09, 2025 12:10 am
 Post subject: Re: Porpoising?
PostPosted: Thu Aug 21, 2014 8:42 pm
I don't have any problem cruising over 40 with mine, agree that is sounds like you are loaded up to heavy in the back...Make sure you aren't carrying around a bunch of water down in the hull that you are unaware of.
PostPosted: Fri Aug 22, 2014 7:55 am
My 2010 A22 will porpoise at wake board speeds if the front is not completely full. This reminds me that I have always wanted to add 200lb of lead to the bow...need to go find some.
PostPosted: Fri Sep 05, 2014 9:57 am
lakedad how to you mount your wicked wave? im looking to get one but I want to use the ratchet strap instead of drilling through the swim platform.
PostPosted: Sat Sep 06, 2014 9:00 am
Also, make sure when you are traveling at higher speeds you have the wedge locked in the up position.
Users browsing this forum: Majestic-12 [Bot] and 45 guests
