It is currently Fri Nov 14, 2025 1:26 am
 Post subject: Re: Ballast Hoses Set Up
PostPosted: Mon Jun 30, 2014 7:07 pm
[attachment=-1]uploadfromtaptalk1404176808450.jpg[/attachment][attachment=-1]uploadfromtaptalk1404176829488.jpg[/attachment]vent[attachment=-1]uploadfromtaptalk1404176845392.jpg[/attachment]
PostPosted: Tue Jul 01, 2014 5:16 am
Thanks bro... I think your missing a couple of pics?
2015 T22
PostPosted: Tue Jul 01, 2014 6:07 am
Are you looking for the center ballast configuration? A lot of that stuff is very tough to get to without pulling off the floor.
PostPosted: Tue Jul 01, 2014 8:41 am
Dezul,
Regarding your rear hose. I see that you chose to re-route the hose out of the back of the hump. Don't you think that's going to cause the bag to not fully empty due to the elevation of the hump? All water below the level of the hump (and as such the fitting) wouldn't drain. Right? Maybe it would if you got the boat on plane?
PostPosted: Tue Jul 01, 2014 9:12 am
I did the same and mine drains through the front pretty well. I have about 1-2inches of water left in the bottom of the bag.
PostPosted: Tue Jul 01, 2014 9:50 am
boardjnky4 wrote:
Dezul,
Exactly what mcmiller said. It was the easiest way to do it so that the drain hose won't kink up. It has worked perfect so far. Not a single issue out of it. My dealer even complimented me on the idea.
PostPosted: Tue Jul 01, 2014 10:43 am
So is everyone removing the shut off valve from the back panel??
2015 T22
Users browsing this forum: Majestic-12 [Bot] and 59 guests
