It is currently Fri Feb 27, 2026 8:02 pm
 Post subject: Sumo Valve Clamps
PostPosted: Sat Jun 21, 2014 6:29 pm
Ok so I bought the new Sumo Axis bow bag hoping the issues they had were fixed... My 1" fitting will not tighten securely... And pop out literally... So now I am having to try to screw on the valve clamps to hold them down... What a POOR way to fix the problem... How did you all install the clamps? They are quite aggravating to say the least.
2015 T22
 Post subject: Re: Sumo Valve Clamps
PostPosted: Sat Jun 21, 2014 7:26 pm
Do u have the right fittings??
PostPosted: Sat Jun 21, 2014 8:22 pm
Yes
2015 T22
PostPosted: Sat Jun 21, 2014 8:26 pm
Get the rings. They will fix your problem.
PostPosted: Sat Jun 21, 2014 8:58 pm
Aren't people still having issues even with the rings?
PostPosted: Sun Jun 22, 2014 7:11 am
I've got the rings
2015 T22
PostPosted: Sun Jun 22, 2014 9:04 am
People as in me? Yes. But they will fix 90 percent of the problem. My hose that kept popping lose has been semi fixed. The rings and some black tape have fixed it to the point only a little air leaks out now. The fitting stays on.
PostPosted: Sun Jun 22, 2014 10:00 am
Does anyone have a pic of this install?
Got my rings this week but not sure how this will keep the threaded part from popping out.
A pic of install would be appreciated.
Thanks
Bama Axis
PostPosted: Sun Jun 22, 2014 10:08 am
I can post pics on Wednesday if nobody else can before then. They prevent the female side of the fitting from expanding when the bag fills up.
PostPosted: Sun Jun 22, 2014 11:28 am
Mine would pop out before i even filled the bag... I have put loctite outdoor on it and it has helped a very small bit... I'm putting the clamps on today...
At this point I wish I had kept my fly high... This has caused me a lot more trouble than what it's worth... To me anyway.
2015 T22
Users browsing this forum: No registered users and 133 guests
