It is currently Tue Nov 18, 2025 1:57 pm
 Post subject: Re: Wow That Just Happened!!
PostPosted: Thu May 08, 2014 8:02 pm
Is there anyway to grind a small section of the lip into a subtle incline to avoid impacting the wheel so much?
PostPosted: Thu May 08, 2014 8:09 pm
that is a really good idea. im going to look into that. ill probably have to do a 3-4 foot section like that. dude, AJ, you are a huge help man.
PostPosted: Thu May 08, 2014 8:18 pm
No prob
PostPosted: Thu May 08, 2014 8:21 pm
Probably cost you less than $100 to find someone that does some concrete work and likes to do a little side work for extra beer money. Maybe check Craigslist or your local classifieds for "Services"
PostPosted: Thu May 08, 2014 8:53 pm
Just get a masonry disk for a hand grinder and do it yourself....If you have the skills. Judging by the looks of the garage...I vote yes.
2014 Axis T22
PostPosted: Fri May 09, 2014 7:46 am
You might look at getting a manual trailer dolly.
http://www.harborfreight.com/heavy-duty ... 69898.html
PostPosted: Fri May 09, 2014 10:18 am
Looks awesome. Was about to go get it but max capacity is only 600lbs. How much weight do you think is on the front part of the boat? I know the jack stands have a 1600lbs capacity so I guess I'll have to find something around that weight
PostPosted: Fri May 09, 2014 10:36 am
Not sure which one would work for you however think those are rated like tongue weight though and that should be around 450-800lbs. Normally tongue weight is calculate at 10-15% of the total weight of the boat, trailer and gear. This is all just a ball park.
PostPosted: Fri May 09, 2014 10:54 am
Awesome. Thanks funky. I found one that has a 1000lbs tongue weight so thinking about going with that. Anyone know what the tongue weight is on a dual axis trailer with a A22 on it? this dolly and grinding down the lip will hopefully solve my problem
Users browsing this forum: Majestic-12 [Bot] and 44 guests
