It is currently Tue Nov 18, 2025 3:18 pm
 Post subject: Adding bags without plug and play?
PostPosted: Fri May 02, 2014 5:43 pm
i was just getting ready to order some sacs, i tired to surf last week and with the stock ballast, it just wasnt happening, but i viewed the install thread first. my boat only has 2 loops in the back and no hoses in the chillax area, so i am assuming i don't have plug and play. so what else do i need to order? i tried to search, but plug and play is too common, haha. oh yeah, 2013 A20
 Post subject: Re: Adding bags without plug and play?
PostPosted: Sun May 04, 2014 5:55 am
Does your invoice/ build sheet say you have it?
store.kultureva.com
Poor Gate Equiped
PostPosted: Sun May 04, 2014 8:43 am
I looked at my build sheet and I don't see it listed. I just see "wakebox 3 tank ballast system - hi flow - std" but it does have the 5 blade Cinco prop and wedge.
PostPosted: Sun May 04, 2014 6:46 pm
Do you have surf gate?
Not that big of a deal, especially with the new ronix bags out now.
You will need a nose bag though.
store.kultureva.com
Poor Gate Equiped
PostPosted: Sun May 04, 2014 7:52 pm
No surfgate, mine is a 2013
PostPosted: Mon May 05, 2014 6:37 am
Ok, get you some rear bags, a nose bag, a good pump, and a poorgate if your a surfer. You'll be good to go! I would check out the new ronix bags for the rear and possibly the nose. you could also do the front bow sac and a tsunami. But 3 ronix bags and one pump would be good. They fill super fast!
store.kultureva.com
Poor Gate Equiped
PostPosted: Mon May 05, 2014 9:29 am
the only custom nose bags for the Axis are the Sumo and Barefoot. Ronix does not have plans for an Axis nosebag. Like VA says you will want a weight in the front if you are going to put some in the rear. If you do not want a bag under the floor you could use one of the Ronix bags on top of the seats and use the super big pumps from ronix.
PostPosted: Wed May 07, 2014 8:23 pm
So basically I would have to add extra pumps? Kinda a bummer, but not too bad, I am a mechanic so I will just start doing a little research and install it myself. I may just add rear bags for surfing or just say screw it and build a surf gate.
PostPosted: Wed May 07, 2014 11:24 pm
You'll still need bags if you build your own surfgate. There's no way around bags if you want a great wakeboard or wakesurf wake.
PostPosted: Thu May 08, 2014 3:30 pm
Hmm, guess I still need to buy some bags then, haha. I guess the easiest thing to do will be just put a T or Y in the stock lines to the bags.
Users browsing this forum: Google [Bot] and 62 guests
