It is currently Wed Nov 19, 2025 7:40 am
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: 2014 A22 PNP Install Question
PostPosted: Mon Apr 07, 2014 12:39 pm
Just another reference and I have mine vented.
PostPosted: Wed Apr 09, 2014 8:56 pm
On those 900s, how did the fit/fill in the A22? Anyone running the 900s in a T22 yet?
2012 Axis A20
PostPosted: Thu Apr 10, 2014 3:30 am
I can give you a better opinion once I connect up the vent hose to the bags. They seemed to form around the structure pretty well when I filled them up without vents.
PostPosted: Sun Apr 20, 2014 10:14 am
Update. So far the sumo bags have been good. I have one fitting that keeps popping out. I think wakemakers lied to me about the sumo bags being the newer version. It is the vent line on the arrow sac. I may need to put a coupling in the line to extend it a little.
PostPosted: Wed Apr 23, 2014 4:41 pm
Straight line or liquid force is sending me the rings that are supposed to fix the problem with hose popping off as soon as I get them in I'll report back
PostPosted: Wed Apr 23, 2014 6:21 pm
Cool. Let me know. Like I said, only issue so far is with the vent hose and it was under a lot of tension. The 1"1/8 hose does not flex like the smaller hose.
PostPosted: Wed Apr 23, 2014 9:00 pm
If it popped off once it will pop off again.. I would get with SL and have them send you some rings to fix it.
Rance report back once you get the rings and let me know if that fixes the problem.
PostPosted: Thu Apr 24, 2014 5:58 am
Ed I will do
PostPosted: Mon May 05, 2014 3:17 pm
Does the 2014 A22 come with that valve shutoff mounted on the short carpeted wall or did it just come loose on the fill hose as in your photo? In the A24 that shutoff valve is mounted behind that carpeted little wall with the LED and only the valve shows in the compartment.
PostPosted: Mon May 05, 2014 6:30 pm
We took delivery of our A22 on friday. The valves are behind the carpeted wall with a notch out of the wall for the handle of the valve to move. Super clean in my opinion. I was poking around today trying to figure out how i am going to hook the bags up. Definitely going to tie into the vent line. The air release knob sounds like a pain for a long term solution.
Kirk
Users browsing this forum: No registered users and 82 guests
