It is currently Wed Sep 10, 2025 4:42 pm
 Post subject: A22 surf vid with surfgate
PostPosted: Mon Jan 27, 2014 11:17 pm
My dealer/Buddy sent me this link. Now it's blowing up all over the interwebs. Not sure if you guys have seen it or not. Pretty sweet wave
http://vimeo.com/84814035#at=0
 Post subject: Re: A22 surf vid with surfgate
PostPosted: Tue Jan 28, 2014 2:22 am
Straight killing it it. Thx for sharing. Wonder what board that is because he pumps the hell out of it. Can't decide if I want a board you have to pump or just butter.
PostPosted: Tue Jan 28, 2014 7:54 am
For most of the video he's riding a ShredStixx Semi Pro - has the serpent on it. (Chase Hazens old model before going to LF). My brother shapes boards in Cali and shaped me a clone of this board. It's an insane board. Wicked fast. Best board I've ever ridden. The other board in the vid is the Headband by shredstixx.
PostPosted: Tue Jan 28, 2014 7:58 am
Wish we knew weight setup!!
PostPosted: Tue Jan 28, 2014 10:25 am
Working on it. I will let you guys know as soon as they get back to me. 8-)
PostPosted: Tue Jan 28, 2014 3:22 pm
I asked him on Instagram and he said stock ballast tanks with 750s in each locker, 750 on the floor centered up the length of the boat, 750 in the bow and wedge with surfgate. He added that it makes a punch wave perfect on both sides and is a great weight setup for wakeboarding.
PostPosted: Tue Jan 28, 2014 4:28 pm
Thanks Steve. My dealer told me that's what they did for wakeboard but wasn't sure if it was the same for surfing.
PostPosted: Tue Jan 28, 2014 5:34 pm
So I am guessing it will get bigger with stock plus 1100s in the rear, arrow sac, plus 800lbs on bow seat, wedge down.
PostPosted: Tue Jan 28, 2014 5:44 pm
I think it depends on how much actual weight the 1100s will hold in the locker. May still have to have another sac in the cockpit.
PostPosted: Tue Jan 28, 2014 6:02 pm
Found a post of Johnny's over on wakeworld helping a guy weight a T22..
"the wave is actually really good with just the plugnplay stock ballast and wedge if you dont want the extra room taken up. but i run my a22 with,750 plugnplay in the rear lockers, 800 in the bow, 800 in the center of the floor and the plug n play front arow with stock ballast and wedge down, i would assume the t22 would be very similar if not better. you want to make sure you weight the boat as evenly forward and back as possible as well as side to side while using the surfgate. throw out all prior weighting knowledge when using the gates. "
So it looks like the he is running the arrow sack as well which I guess should be assumed with anyone running an A22.
Bow = 1750lbs -- 950 nose bag plus 800 on top
Mid = 1300lbs -- 500 center tank and 800lbs on the floor
Rear = 2000lbs -- 250 tanks + 750bags on each side
total of 5050lbs then the wedge and surf gate.
Users browsing this forum: No registered users and 91 guests
