It is currently Fri Nov 21, 2025 10:32 am
 Post subject: Axis A22 with tower down and cover on
PostPosted: Wed Aug 28, 2013 6:36 pm
I park my boat in a carport. The clearance is too low to leave the tower up, and the exposed sides make me use a cover to ensure no rain or stray cats get in my boat. Before I bought this boat I looked all over the internet for the answer to the following question:
Can you put down the tower on an A22 with the cover on?
Here is that answer.
Hope it helps someone else...
 Post subject: Re: Axis A22 with tower down and cover on
PostPosted: Sat Aug 31, 2013 9:39 am
I put my cover over the tower when it's down, it doesn't fit perfectly but it still fits
PostPosted: Sat Aug 31, 2013 12:10 pm
Like so
PostPosted: Tue Sep 10, 2013 10:42 pm
I do the same as amsugg for winter storage
PostPosted: Wed Sep 11, 2013 6:26 am
Do you guys just let the support arms rest on your seat cushions?
PostPosted: Wed Sep 11, 2013 6:27 am
And also I have the tower mount mirror...Do you guys take that off each time?
PostPosted: Wed Sep 11, 2013 7:08 am
Hey X_40oz and Amsugg, could you let me know how high your rigs are with the tower down. I have an A22 and this year I might be able to store it inside a low garage (80")??? Also, Amsugg I'm wondering how hard it was to take off the wide arms of the tower, and how you did that?
Thanks in advance!
2009 A22
Wood Lake, BC, Canada
PostPosted: Wed Sep 11, 2013 8:34 am
From axiswake.com it's 82".
Axis A22
Garage Specs
Total Length
24'3"/7.39m with platform installed and trailer tongue folded
Total Height on Trailer
6'10"/2.08m (tower folded down)
Total Width on Trailer
102"/2.59m at guide posts
PostPosted: Wed Sep 11, 2013 9:00 am
x40oz - I have a wooden support that holds the tower off the seats and keeps the mirror mount from hitting the lower tower arm.. I also leave my mirror mount loose enough to move it but tight enough to keep its self in place, so I just push it down below the windshield. I posted picks in another thread of mirror arm deal, and also there was a thread about the tower supports aswell
flyguy - the side tower supports should have knobs just like the tower does, so once the two that hold the bottom are removed it comes right off. I estimate my garage height at 7ft I don't know what that is in inches but mine clears by about an inch
PostPosted: Wed Sep 11, 2013 9:08 am
viewtopic.php?f=14&t=1816 - mirror thread
viewtopic.php?f=14&t=695&hilit=tower+support - tower support thread, mine is a lot simpler then the ones in this thread but you will get the idea
