It is currently Wed Sep 10, 2025 7:55 am
 Post subject: How will this sound?
PostPosted: Mon Jul 29, 2013 6:40 pm
I think this is going to be my system, let me know what you think.
4 rev 8s on tower with syn 2 amp
6 wetsounds cabins + sub with syn 4
Wetsounds 420 Eq
Will this setup sound good? Or do I need to make changes?
 Post subject: Re: How will this sound?
PostPosted: Tue Jul 30, 2013 5:08 am
You need two syn 2s for tower, 1 per pair. I run a syn 4 to my 3 pairs of xs650s. I'd say you need a syn 6 for inboats and sub, depending on what sub your running.
PostPosted: Tue Jul 30, 2013 5:40 am
I was going to go with a syn 4 for my tower speakers but I was told the syn 2 would put more power to each speaker. I also was thinking I might need a syn 6 but was also told that the syn 4 would work fine with my in boats and sub. The sub is factory mtx might change it out as well.
PostPosted: Tue Jul 30, 2013 5:57 am
Syn 4s are ideal for one pair of rev 10s. Syn 2 is ideal for 1 pair of rev 8s. Maybe you could look at the SD series amps. That would let you use 2 amps instead of 3 or 4, but they're expensive! I'd run 2 syn 2s to the tower, syn 4 to inboats( left side cabins in parallel to Chp 1, right side cabins parallel to chn 2, left bow to 3 and right bow to chn 4). I like a ton of bass so I ran a 13w7 off a jl 1000/1. There's a lot other ways to do it tho, you'd just be sacrificing a ton of power running the inboats and sub off a syn 4. You'd have to bridge the sub to chn 3 and 4 because you can't just run 1 chn on lo pass. So running 6 speakers on chn 1 and 2 means you'd b running at like 1 ohms. Big no no IMO.
PostPosted: Tue Jul 30, 2013 7:24 am
Bryce is correct. Go with 2 syn2's for tower and then a syn for sub/cabins. 1 SD2 should cover the tower, but you'll be on the lower side for watts.
I'd do an SD4 for tower and then syn6 or SD6 for cabins if I were redoing my system.
PostPosted: Tue Jul 30, 2013 8:32 am
I'm going to throw another is
Idea at you for your tower. 2 rev10's off a bridged syn4. Also have you talked with Dave at earmark? He's the wetsounds guru.
PostPosted: Tue Jul 30, 2013 10:48 am
I like the look of 4 speakers on the towers and rev 10s will be tight under my z5. I have only talked with my dealer and wetsounds.
PostPosted: Tue Jul 30, 2013 10:56 am
I'd call Tim at wet sounds, he'll tell you exactly what would be best for 4 rev8's, but I do think if you run them at 2 ohm on the syn2 you will be close to the right amount of power, it's rated at 350 x 2 at 2 ohm and that's underrated, probably will make closer to 375-385 rms, which is close to what 2 rev8's can handle on each channel, but call Tim before you make any decision.
PostPosted: Tue Jul 30, 2013 2:14 pm
Users browsing this forum: No registered users and 111 guests
