It is currently Wed Nov 12, 2025 9:25 pm
 Post subject: Cracks around drive shaft mount
PostPosted: Fri Jun 14, 2013 10:08 am
While installing a new prop, I notice some small cracks around the mount that holds the drive shaft. They do not seem very deep but a few are slightly raised enough that I can feel them with my fingers. Is this something to be concerned with?
 Post subject: Re: Cracks around drive shaft mount
PostPosted: Fri Jun 14, 2013 10:33 am
before or after prop install
PostPosted: Fri Jun 14, 2013 10:45 am
I noticed them when i was removing my original prop to replace it with the new 1235 i just purchased.
PostPosted: Fri Jun 14, 2013 11:00 am
That could have happened when you damaged your original prop, probably just minor flex of the fiberglass, most likely just cracks in the gelcoat, I wouldn't worry too much unless they started spreading out more
