It is currently Tue Nov 11, 2025 7:43 pm
 Post subject: Impeller change issue
PostPosted: Sun Jun 02, 2013 2:35 pm
2012 Axis A22 trying to do impeller change loosen bolts that hold housing but having trouble slipping housing off crankshaft should it be that hard.. ? Thanks Dave
 Post subject: Re: Impeller change issue
PostPosted: Sun Jun 02, 2013 2:52 pm
Have you tried just pulling the cover and leaving the pump in place - viewtopic.php?f=14&t=77&hilit=impeller&start=10?
PostPosted: Mon Jun 03, 2013 6:28 am
Thanks for response got it off the crankshaft finally.. Tight fit.. Dave
