2015 Axis Plug n play plumbing in rear lockers http://www.axiswakeboardboats.com/viewtopic.php?f=15&t=3101 |
Page 2 of 2 |
Author: | kx250frider617 [ Sun Jun 21, 2015 11:36 pm ] |
Post subject: | Re: 2015 Axis Plug n play plumbing in rear lockers |
Hmm, yours guys rear bag drains are set up way different than mine. I have two bag drains: 1 goes into the front of the tank, the other goes to a T-fitting that is connected straight to the pump. My bag and tank drain at the same time. |
Author: | alehr151 [ Mon Jun 22, 2015 11:23 am ] |
My T23 only has two hoses. I noticed yesterday when I was out one of them got kinked and needs to be replaced i would recommend turning the bags at a slight angle to prevent this |
Author: | SomeYeahoo [ Tue Jun 23, 2015 10:28 am ] |
I don't know why they tuck that one way up there. I had to call the dealer to get the info in this thread. It was surprisingly hard to find. |
Author: | ARpowhound [ Mon Aug 31, 2015 5:13 am ] |
Hodi42, where did you buy the elbow you have on the rear drain quick connect? Is it a barb end elbow on both ends? With a short piece of hose connecting to quick connect fitting? I was thinking of doing the same thing, so I could move the bag back all the way. Nice post. Thx. |
Author: | alexandera [ Mon Aug 31, 2015 7:05 pm ] |
Wakemakers has them... I used 2 barbed 90s in lieu of two quick disconnect fittings. |
Author: | PotatoShack [ Mon Aug 31, 2015 7:35 pm ] |
Question. Why not cap the vent line from hard tanks and move vent to PNP bag eliminating the Y fitting. |
Author: | ARpowhound [ Mon Aug 31, 2015 7:51 pm ] |
Thx. I found that one on Wakemakers. The reason for the 2 vents, are so the hard tank won't need to be "burped". Should help it drain better. Some don't have a vent on the bag, but then you need an air vent cap in the top of bag to let air out. So why not vent both. I have read that some say you need a check valve on the vent hose to keep it from siphon draining. |
Page 2 of 2 | All times are UTC - 6 hours |
