It is currently Wed Sep 10, 2025 1:51 pm
 Post subject: depth gauge erratic readings
PostPosted: Sat Jul 16, 2016 5:45 am
I'm getting fluctuating readings on the depth gauge. It will go from say 15 ft. to DEEP, then jump back. At first, it seemed anything over 30' was reading DEEP, but it has become progressively more erratic.
I have no idea how the system is set up, where the sensor is, or how it reads?
Two questions:
Anyone had this issue?
Anyone have insight into how the system is set up...will assist me in trouble shooting.
 Post subject: Re: depth gauge erratic readings
PostPosted: Sat Jul 16, 2016 6:39 am
I've heard of low battery voltage giving erratic readings. Mine will give spurious low depth alarms in the middle of the lake at times after I've been sitting on a single battery without the engine running.
PostPosted: Sat Jul 16, 2016 7:32 am
Is it happening while you are moving?
Prop cavitation will cause sporadic readings in reverse.
PostPosted: Sat Jul 16, 2016 11:14 am
Yes, typically while moving. Any speed. Mainly between 13 mph to cruising speed...23 mph.
PostPosted: Sun Jul 17, 2016 7:56 am
Mine is very erratic while moving at those speeds too... I think there is too much 'noise' along the water surface.
I have a decent finder in my fishing boat, and it does the same thing at those speeds...
PostPosted: Mon Jul 18, 2016 5:17 am
Thanks for the feedback. It didn't do this in the first summer of operation, and just recently started giving the varied readings. I'll keep an eye on it
Users browsing this forum: No registered users and 90 guests
