It is currently Wed Sep 10, 2025 9:13 pm
 Post subject: 2016 T22 bow bag won't drain
PostPosted: Sat May 28, 2016 1:09 pm
I have a fly high under seat bow bag with plug/play and it won't drain unless I stand on it the whole time the pump is on, anyone else have this issue? If so did you fix it and how
 Post subject: Re: 2016 T22 bow bag won't drain
PostPosted: Sat May 28, 2016 4:51 pm
Is it the actual T series triangle flyhigh bag or did your dealer just throw in a triangle sac.? I have a 2016 A20 running the T-Series flyhigh bag and it drains fine. I did cut my drain line down though.
PostPosted: Sat May 28, 2016 4:59 pm
The hose on the right is the drain line, I cut it and added in a 90 degree fitting and the other line that hooks to the sac is just long enough to hook to the drain port on the fly high bag.
PostPosted: Sat May 28, 2016 6:21 pm
Yes, it's a T series bag and all the lines look good that's the weird thing, I pulled the sub and looked at those lines and they look good too(not long or short) the thing will loose prime if if I don't stand the on the bag the whole time, but it does completely drain bag that way.
PostPosted: Sat May 28, 2016 6:51 pm
Do you have the drain line running under the bag or on top of the bag?
PostPosted: Sat May 28, 2016 7:23 pm
I just looked at the lines after I looked at your pictures and the drain line was held up by the fill line, so l moved those lines and made sure the drain is under the bag. I'll go out in the morning and see if that helped. Thanks for the help
PostPosted: Sun May 29, 2016 11:19 am
Well this won't be a simple fix so I'm going to let them do a little warranty work I guess, I'm thinking it might be the loop under the dash
Users browsing this forum: No registered users and 172 guests
