It is currently Thu Sep 11, 2025 5:45 am
 Post subject: 2015 T22 plug n play install
PostPosted: Wed Mar 30, 2016 3:06 pm
About to do the install with my wakemakers package
800 lb rear sacs
650 lb bow sacs
Any recommendations or tips/tricks for the install? Just want it to go smooth and have no issues once we out the bot in the water in late April
 Post subject: Re: 2015 T22 plug n play install
PostPosted: Wed Mar 30, 2016 3:38 pm
Pretty straight forward if you have all the fittings. The front line is "y-ed" together so you have to remove that piece and then you have your fill/drain/vent. The rears do not come with vents so you will only have 2 drain lines on the floor and one fill line on the top.
PostPosted: Wed Mar 30, 2016 6:58 pm
Sorry to be a newbie...but if the rears don't have vents do you have to burp them all the time? Would this be the same on a 15 A20.
PostPosted: Wed Mar 30, 2016 7:36 pm
Yes. You have to vent them everytime. It sucks. You can add a vent easily, search my posts or others and you'll see how to tie into the rear hard tank vent lines so you don't have to the burp the bag anymore.
PostPosted: Wed Mar 30, 2016 8:21 pm
Is it the post where you refer to dezuls post from 2014?
PostPosted: Mon Apr 04, 2016 9:47 pm
Yep!
Users browsing this forum: No registered users and 97 guests
