 Post subject: 2015 350 PCM Gearing and Prop
PostPosted: Sat May 02, 2015 6:43 pm
Anyone with the new gearing on a 2015 Axis have any input on props?
I see the altitude prop is the 1235. I'm not sure what is the torque prop when you order a new 2015.
2015 T23
PostPosted: Sun May 03, 2015 7:43 am
I have a '15 A22 on the way and decided on the 1235. The torque prop is the 2313 and is a beast with the new gear ratio from what I've heard. I know a couple of members here have used it so they can tell you about rpms and top speed. The 2015 Props thread has some good info too.
 Post subject: Re: 2015 350 PCM Gearing and Prop
PostPosted: Sun May 03, 2015 8:29 am
I have used the 1235 and an OJ 945 (15x13). I have the 945 on now and here are my findings
ballast set up:
stock +wedge+600s in the lockers+bow bag+5 peeps
surf 10.8 3600-3700 rpm
wakeboard 22.5 4100 rpm
top speed 34 mph
I cruise to the ride spot around 4000 RPM's at 28-30 MPH
the 1235 runs at slightly lower RPM's but doesn't get out of the whole like the 945. The 1235 still gets out of the hole fairly easy with this weight setup.
like jayman said the 2015 prop thread has some good info too.
PostPosted: Mon May 04, 2015 1:59 pm
2015 A22 with PCM 350, prop 2313.
Prop is a beast but we only wakeboard and then surf occasionally. Def no high speed cruising on the lake.
Ballast: stock 900+ wedge, PnP 1100s in back and 750 sumo IBS. Very impressed with getting in plane and for wakeboarding, fuel consumption is not as bad as I thought it would be 4000rpm @22.8mph.
It drinks it quick while surfing.
