It is currently Thu Sep 11, 2025 12:54 pm
 Post subject: Is the captain's seat removable?
PostPosted: Mon Apr 21, 2014 6:02 pm
I tend to do things under the dash and I am just a little too chunky to squeeze between the seat and the wraparound seating. Is it removable?
 Post subject: Re: Is the captain's seat removable?
PostPosted: Mon Apr 21, 2014 7:14 pm
Should be a little black cover with 6 screws on the front of the base. Take that off and then a 9/16 to the 4 nuts underneath there. Careful not to drop a nut or the fender washer. Once all 4 are off lift seat straight up and then be stupid careful as the studs will be sticking straight out the bottom. 10 mins tops.
PostPosted: Tue Apr 22, 2014 3:12 am
I was looking for a quick release. That sounds like entirely too much work. I may in the future look at raising my seat about 4 inches so I will keep this in mind.
PostPosted: Tue Apr 22, 2014 9:49 am
Good info, I may do this soon. Unfortunately got a small vinyl tear on the backside of the captains seat, it isn't very big but I know it's there and it's very annoying. I'm thinking my best bet is to remove the seat and take it to an upholstery shop to have the back section re-skinned.
PostPosted: Wed Apr 30, 2014 10:29 am
yeah its removable but its a pain .... got to do what you got to do tho
PostPosted: Thu May 01, 2014 10:34 am
what were you doing in the above pic? AXIS is new, no reason for tear down yet....
PostPosted: Thu May 01, 2014 10:45 am
I was installing the heater
PostPosted: Thu May 01, 2014 1:42 pm
wow, removable floor makes the boat easy to work on aye? too bad it's brand new to me and i have no reason to be working on it, unlike my old boat.
PostPosted: Thu May 01, 2014 7:18 pm
The remivable floor doesn't help as much as you might think. It gives access to little more than the fuel tank. All the pumps and valves and drain plug up front are accessed through the small round access you can see by the observer seat.
PostPosted: Fri May 02, 2014 11:10 am
you can access the front pumps a little easier with the floor removed ..... I just slid it back a little bit so I could get both arms under there and then used the floor as support so I wasn't laying on the gas tank
Users browsing this forum: Google [Bot] and 74 guests
