It is currently Tue Sep 09, 2025 3:32 pm
 Post subject: Make and Model of Rear Ballast Pump 2011
PostPosted: Wed Jun 27, 2012 3:34 pm
My repair shop claims I need a new pump and they can't get one. Does anoyone have access to tehir boat that can look at their rear ballast pump and give me the make/model? It will help me find a replacement. Thanks!
PostPosted: Wed Jun 27, 2012 3:55 pm
I just replaced one of my rear drain pumps with the attwood tsunami T800. It actually drained faster than the stock piranha pump so I swapped the other side out as well.
 Post subject: Re: Make and Model of Rear Ballast Pump 2011
PostPosted: Wed Jun 27, 2012 5:36 pm
Thanks, I may go that route. You said "drain pump", does that mean there is a fill and drain pump? I had thought it was a reversible. Should be much cheaper then. I'd liek to keep them the same, and since I only have to replace teh one for now, I will do the pirhana. I assume this is it: http://www.wakemakers.com/shurflo-piran ... alibu.html
PostPosted: Wed Jun 27, 2012 6:30 pm
The drain pump is a separate pump than the fill. It's in the far back of the rear storage (closest to the transom). There are three screws to remove to get to the compartment where it's held. You may actually be able to just replace the motor part of that pump like a drop in part. I know you can with the tsunami pumps. It'd save you a few bucks if you can. Someone else may be able to chime in and confirm that.
Users browsing this forum: No registered users and 130 guests
