It is currently Tue Sep 09, 2025 10:32 am
 Post subject: Loose throttle shifter
PostPosted: Sun Oct 15, 2017 9:02 am
Anyone have a throttle shifter get loose mine, has gotten "loose" don't need to use detent for it to shift in or out of gear and it seems "tough" to find neutral. Seems like the detent will drop in but you have to play to find "neutral" even after that, there is some play there with the detent in maybe 1/2" play, (with engine off you have to play with shifter handle for it to start in the neutral position)
If you are pushing against the base of the shifter you can find neutral and it works fine it seems to have gotten a bunch of slack.
Seems like this just started to be an issue
I was hoping there was a easy way to tighten it up
Boat is 2016 T23 w 450
Thank you
2016 T23
prior
1998 Super Sport Nautique
Users browsing this forum: No registered users and 125 guests
